timberwolf
Old Feb 21, 2000 | 11:32 PM
kws's Avatar
kws
twolf is missing when it is idleing put a new k&n airfilter on it but it did not help. has anyone else had this problem... if so what was the fix.
Old Feb 22, 2000 | 10:41 AM
95TimberWolf's Avatar
Ya i have had the same problem with mine every noe and then right now my problem is that it kills it self after you have been riding in 3rd gear or high at 1/2 throttle or higher. if any of you have the same problem and have fixed let me know what you did. try lowering the needle clip on the needle jet or raising it or your idle might be screwed up, there is an idle adjustment screw on the carb. these are just my suggestions though. dont knwo if they will work but they are a try.
Old Feb 22, 2000 | 11:42 AM
Harold's Avatar
sounds like you could have some trash in the idle circuit, spray a good carb. cleaner in the intake while running until the atv cuts off, let it sit for several hrs. hope this helps.
Old Feb 25, 2000 | 08:15 PM
timberwolf_99's Avatar
I also have an idleing problem w/ my 99' timberwolf. I can ride it for an hour and it will still cut off after a while. I take it to my dealership and when they adjust the valves it seems to help it for a couple months. Sean Sicher
99' Timberwolf
Old Feb 25, 2000 | 09:04 PM
86Honda200SX's Avatar
Unless you upped the main jet a little it will be running extra lean with an aftermarket filter.The cutting out sounds like a CDI box or just a plain good ole' carb needing cleaning.
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 9, 2015 02:28 AM
atc350
Jun 27, 2000 11:48 AM
95TimberWolf
Mar 14, 2000 10:33 AM
Brian_Kimmel
Aug 9, 1999 02:24 PM
