recon wheelies
Old Mar 14, 2002 | 04:37 PM
01redrecon's Avatar
Im a 16 year old and onloy weigh 110 pounds and it is hard for me to wheelie my recon without popping the clutch. I know popping the clucth is hard on a bike, but will it hurt my clutch if if a do every now and then. and im thinking of putting a set of tires on for trail/mud/snow any suggestions would help.
Old Mar 14, 2002 | 05:41 PM
KILLER250R's Avatar
If your only poping the clutch every now and then it will be OK. But if you do it alot than after tiem you can kiss your clutch goodbye, I ruined my old recons clutch be doing that.
Old Mar 14, 2002 | 06:21 PM
RubiconMan500's Avatar
I thought the recon had an auto clutch?
Old Mar 14, 2002 | 06:27 PM
KILLER250R's Avatar
By pushing down on the gear shift lever slightly (not quite shifting down) you can rev the motor and have it inbetween gears, when you let off the lever it pops the auto clutch.
Old Apr 2, 2002 | 08:21 PM
onenice88's Avatar
Stay away from popping the auto clutch suddenly into gear. This is pretty bad for the tranny. As for tires try GBC Dirt Devils 22x11x9. They're pretty cheap and work relatively well.
Old Mar 27, 2006 | 04:32 PM
CanadaBiker's Avatar
Default recon wheelies
If you can't get your recon up without popping it into gear you aren't doing something right. I can do a wheelie all day without popping the clutch at all. Try putting your knee on the seat and haul on the bars in second. i can go from 1st gear to 4th.
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
