350x carb,throttle question.?????????
Old Mar 19, 2002 | 10:51 PM
350rcherdude's Avatar
i have a problem, i just bought this near mint 1986 honda atc 350x and it runs really strong. but when i give it gas it feels like it has a throttle stop. but there isnt any. and if you put a lot more effort in to it it will take off. it doest it at about mid throttle. i could not figure it out. any help would be much appreciated. and i just took off the brass plate at the top of the carb nothing was clogged and the plastic cover on the side there was a little dirt in it but nothing to bad.? i dont have a clue and it is bugging the hell out of me. thanks again for any replys.
Old Mar 19, 2002 | 11:08 PM
KNOWSALOT's Avatar
The Facility
Sounds like maybe the throttle cable is binding. Take the cable loose from the carburetor and take the 3 screws that hold the throttle housing cap on.
Push the throttle and see if it's going the entire travel until the arm in the the throttle housing reaches it's limit. Then look at the carburetor end of the cable to see if it's bottomed out. There is a possibility that your cable has a kink within the cable housing somewhere if this doesn't work.
Old Mar 20, 2002 | 11:19 AM
it only does it when it is running that is what i dont get.it is weird some times it goes and runs smooth but other times it feels like a throttle stop on it.and some times when it is sitting i am stumped.i will try what you said.thanks.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
GregM
Mar 6, 2018 06:53 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
