Need a little advice....
Old Apr 5, 2002 | 12:34 AM
BadassGTstang's Avatar
I just bought a PRM bumper for my warrior. The reason I got it is because my stock one is bent up from the wreck I had in a race last summer. It bent the right side down an inch or two where the bar mounts up. What I need help with is what is the best way to go about bending it back up so I can get my new bumper mounted right? Ive tried whacking it with a hammer with no luck. I was hoping that someone might have a little trick to get this thing bent back. Thank you[img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 5, 2002 | 02:47 AM
THEMOOSE's Avatar
Chain it down solid & put a jack under the low side & SLOWLY jack it up till it's level with the other side. Be cautioned though if it's bent bad enough it may crack a weld or tube & be careful what you use to tie it down , if it's not as strong as the part your straighting you may rip it off. Do it at your own risk.
TxMagnum
Aug 4, 2012 11:59 PM
88Banshee88
Aug 1, 2012 03:09 PM
vonDS
Jul 20, 2010 11:50 PM
