More speed please
Old Feb 27, 2000 | 09:09 PM
WhiteWarrior's Avatar
I have a 96 warrior and want more speed I have a pipe, k&n filter, and different sprockets, do they make smaller than a 40 tooth for the rear? Any suggestions on how to make it faster without sacrificing my bottom end.
Old Jun 7, 2000 | 09:40 PM
hot_shoe_cv's Avatar
It sounds like you've done all you can via bolt ons. You next step would be to get into the engine and either get a kit or do it piecemeal with a bore/stroke job . etc., since you already have the cam & piston. Or you could wait a few mos. for the new Yamaha Raptor or one of the other new machines. You might check with Sidewinder on the rear sprocket situation; I think they will make any size sprocket you are willing to pay for
Old Jun 8, 2000 | 12:32 AM
EasterEgg's Avatar
WhiteWarrior
You can only go to a 39 tooth rear because of the sprocket hub size so all your changes will need to be to front sprocket.
Heres what I did to my 92 Warrior and was quite happy for a while.
FST 435 kit installed by them
10.5 to 1 comp.
White Bros. woods cam
Titanium retainers HD springs
Head ported & polished (by a flat track motorcycle racing buddy) also polished and matched intake.
Carb bored to 37mm
Pro Design filter system with K&N
RCM exhaust with head pipe
14 39 gearing
Works suspension and Holeshots
Didnt go with the higher comp. or big cam because I didnt want to run race gas. Mostly used for Hare Scrambles and Ice Racing and trail riding. Would not beat a Banshee in a drag race but it was close and in the woods he could not pull away.
Reliability was great once the bugs were sorted out. Ran this engine for 3 years only 1 problem and it was my fault.
Ice racing and I over reved it exhaust valve hit the piston not a good thing. If you make the Warrior breather a lot better you have to becareful as there is no rev-limiter and it will over rev enough to float the valves.
Sorry so long have a lot of past experience hopping up a Warrior and thought I would remenis as well as help you.
98 SC 500
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
