700 grease zerks
Old Apr 13, 2002 | 08:37 AM
hausdog's Avatar
How many grease zerks are on the sp700? Does the steering shaft have one? Never greased it and dont have my book.
Old Apr 13, 2002 | 08:49 AM
sportsman43's Avatar
never counted them all ,,but there are alot,,yes there is a fitting on the top of the steering shaft,,access it from the front,,under the headlight pod...
sp700,,feel the power,,
Old Apr 13, 2002 | 09:07 AM
hausdog's Avatar
how often do you grease?
Old Apr 13, 2002 | 11:33 AM
i only have 70 miles on my sp700,,i just greased them this week,,they took alot of grease,,the factory must not put much in them,,i have a creek in my back yard ,,after i get it all muddy ,i always ride up the creek to clean it off,so i grease them often,,every 50 miles or so..alot of water came out when i greased them,,,
Old Apr 13, 2002 | 11:55 AM
hausdog's Avatar
Boy did I drop the ball...I have 361 miles on mine, never have greased it. Thanks for the info.
Old Apr 13, 2002 | 02:56 PM
500DUSE's Avatar
Yelp .....try greaseing alittle more.[img]i/expressions/face-icon-small-happy.gif[/img]
I try to do mine before or after every ride.
Use a good greese(I like mobil 1)
Old Apr 13, 2002 | 10:11 PM
badfordman's Avatar
THE REASON ITS CALLED A 700 IS NOT THE CC'S ITS THE ZERKS.
Old Apr 14, 2002 | 05:14 PM
VeryPicky's Avatar
Their are 24 fittings on both the 700 and 500 but the latest models coming from the factory have 22. That is because polaris did away with the 2 fittings on the anti-roll bar on the back of the machine. One on each end of the roll bar. Don't know why they did this other than to save money. Two different dealers have told me that the roll bar is now pre-greased from the factory. The Five fittings that are on the U-joints take the polaris black grease and the rest take the polaris green grease or the grease of your choice as some of the other owners do. Myself, I use the polaris grease. Their is one fitting on top of the steering post that you access under the front of the headlight pod as other owners have stated. You will probably have to move wireing around under the front of the headlight pod to see it. I just try to spread the wireing apart with my fingers and try to get it to stay there till I can get the grease gun on it. I grease after every time I ride in deep mud or water. Cheap maintainence. I probably misspelled that. And that too. Get grease guns with the flexible hose and the job will be a lot easier. As I stated, my 700 has 24 fittings as does my sons 02'500 h.0. My other son's 02' freedom edition 500H.O only has 22 fittings, minus the 2 on the roll bar. I've got the job down to about 30 minutes but that is after greasing sometimes 3 atv's a week or more. They always claim they can't find the fittings. You'll probable see other posts where other owners have 69, 102, 16 or some other amount of fittings but their are either 24 or 22 depending on if your roll bar has them. Hope this helps!!
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
