Reverse on a 300EX
Old Nov 23, 1999 | 08:03 PM
LT230S's Avatar
How can I get rid of the limiter without voiding my warrenty? Thanks
Old Nov 23, 1999 | 10:43 PM
qwiktim's Avatar
The reverse inhibitor? Easy, on the lower right side of the motor by the rear brake pedal there is a small black cover with two screws in it that covers the reverse and neutral switches. Remove that and unplug the forward switch, which is the reverse switch. You will need to make up a small wire with a male push in plug to push into the connector and then ground the wire to one of the bolts that attach to the cover. When this wire is grounded the bike thinks it isn't in reverse even when it is. Your reverse inhibitor will be bypassed and you can have full throtte in reverse. The red reverse indicator light will not work with this done, but no big deal. Also, if you follow that wire up to the big connector by the fuel shut off, you can unplug and ground it there if you like. Whichever, they both do the same thing.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
poutlaw525
Sep 9, 2015 03:19 AM
