Sportsman 500 HO won't stay running?
Old Apr 21, 2002 | 08:27 PM
axisII's Avatar
The machine is a 2001 sportsman 500 HO, and prior to last weekend i have had no problems with it. I took it through some fairly deep water and ran though some shallower puddles at high speed. A few times after going through the water, the engine would bog when giving it full throttle and wouldn't idle w/o stalling. This cleared up after riding for a few minutes but then came back after going through only a foot of water (at like 20 mph). It has been a week and the machine still will not idle, and only goes about 25-30 mph top speed because it keeps bogging down (but not when accelerating, only at top speed, it accelerates hard?). If anyone knows what i got wet and how to fix it i would greatly appreciate it.
Thank you
worried SP 500 owner
Old Apr 21, 2002 | 09:52 PM
GE4x4's Avatar
This happen to mine. My problem was the breather hose to the carb was plugged, cleaned it out, now she runs fine. Give it a try.
Old Apr 22, 2002 | 02:40 PM
Maddoggy's Avatar
You should also drain the float bowl on the carb. It could have water in the bottom. I had this problem and that cleared it up. (bad gas)
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
skittero
35
Mar 1, 2019 12:39 AM
kbbgood
Utility ATVs
24
Mar 9, 2016 03:08 PM
jayking232003
Jun 9, 2015 02:54 PM
