700 Clutch Spring
I am looking for opinions on what spring will give me a better hole shot? Is there one spring that will give me that and a little more top end. Do you need to change both springs? Lots of questions...looking for a few answers.
Thanks.
Thanks.
Contact AAEN Performance (262)-552-8981
I recieved a catalog from AAEN and inside was a special sheet on the 700.
""There is a problem with the secondary clutch. The two belt sheaves are rubbing on each other at low ratio. It takes power to overcome the friction, and the result is a jerky and inconsistent shift. This can be fixed with 5 shims (Included in there Clutch Kit) on the shaft between the sheaves to space them away from each other (.010 to .020). This Mod results in a smooth take off and better acceleration. The kit also includes Green Primary for 300 RPM higher engagement, and heavier weights for harder midrange acceleration.""
Stage 1 Clutch Kit ATC30056 - $55.00
cdstang
Aug 31, 2015 07:52 AM
