Amazing Scrambler runs off water!
Old May 12, 2002 | 10:48 PM
KEP's Avatar
KEP
My Scrambler 400 2 stroke is getting water into the exhaust somehow. It runs fine but it eventually overheats from a lack of coolant. I can tell that is where the coolant is exscaping to because there are no leaks at hoses or the radiator and there is steam mixed with the exhaust. My first thought was a blown head gasket so I replaced it but the problem still exists. I pulled the jug and there is gray oil/water gunk around the crank. Could the base gasket have caused this? Something worse? I looked for cracks in the head and cylinder but they look good. It only has about 130 hours on it. Has anyone got any ideas or seen this before?
Old May 12, 2002 | 10:56 PM
Rockey's Avatar
Check the compression on your engine. You can also run the engine and look inside the radiator, if you see bubbles then you have either
1: blown head gasket
2: cracked head
3: cracked cylinder
Sometimes parts have to be magnafluxed to determine where the crack is.
Old May 13, 2002 | 05:51 PM
harescrambler's Avatar
IF its none of thee above check the water pump seal
Old May 13, 2002 | 10:06 PM
Gramps's Avatar
When my oldest son was five he used the gas can as a toilett but the
scrambler dident run very long on that mixture . If your water pump
seal is wore it could leak into the crank case .
polaris scrambler00
Jun 20, 2015 08:49 AM
robj
Jun 15, 2015 08:45 PM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
chrisjack
Aug 21, 1999 04:52 PM
