replacing A-arms on my Speed
Old May 13, 2002 | 01:31 PM
Alaska400EX's Avatar
Well,
I am going to get some new a-arms and wanted to know from anyone that has replaced theirs on the Cannondale if there was anything to worry about as far as problems that arose during the removal and installation process. Do I need any special tools to remove ball joints or tie rod ends from the spindles? I just want to be ready for anything, thank you, JIM
Old May 13, 2002 | 01:56 PM
jcv400ex's Avatar
Yeah.....patience! lol
Good luck to ya!
Old May 13, 2002 | 02:01 PM
I just talked to Kyle at R&S and he said you won't need any special tools, just tap with a rubber mallet.....JIM
Old May 13, 2002 | 02:12 PM
briansgi's Avatar
A big hammer!! Haven't done my Cannibal but went through this process on my R, a big hammer helps. Do the lower a-arms first, jack up the front end, remove your ball joint nut and as your holding up the top a-arm, hit the spindle housing where the ball joint goes in. Pull up on the upper arm as you tap/hit the spindle, the ball joint should pop right out, then do the upper ball joint the same way. Some people may tell you to invest in a ball joint removal tool but that's not necessary. The ball joints should come out pretty easy since our C'dales are so new. Tie rods come off easy, a couple wrenches is all you need, pretty self explanatory once you look at them.
Old May 13, 2002 | 02:17 PM
jcv400ex's Avatar
Yeah, with the Dale being new, it's going to be a breeze. The hardest part will be setting the toe-in to your preference.
Old May 13, 2002 | 02:33 PM
briansgi's Avatar
jcv400ex is correct, you're going to spend more time adjusting the "alignment" then you will replacing the a-arms.
Old May 13, 2002 | 02:48 PM
...so what you are saying is bring a few music cd's and a 6 pack of beer out into the garage? JIM[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 13, 2002 | 03:07 PM
briansgi's Avatar
Alcohol is optional, depends if you want to go down the track straight or not!![img]i/expressions/face-icon-small-wink.gif[/img]
Ramman1
Jun 16, 2016 09:07 PM
bpegram84
Jul 22, 2015 08:15 AM
musselmark
Jul 17, 2015 02:40 PM
Scottma518
Jul 16, 2015 09:19 PM
ranvette
Jul 12, 2015 06:34 AM
