My xplorer cant keep up to 500 magnum
Old May 14, 2002 | 07:53 PM
midnightxplorer's Avatar
What do i have to do to keep up to my dads magnum?????
I already have it
40 over
racing reeds
K&N
EBS clutches
thanks
Old May 15, 2002 | 10:16 AM
boneylong's Avatar
it is either way out of tune by the way you have the carb jetted or it is ready for another rebuild.a stock 400 xplorer will dust a 500 magnum.i had no trouble dusting my friends 500 ho with my 400xplorer and it was stock.
Old May 15, 2002 | 10:39 AM
MegaCrash's Avatar
I would agree,
I have often seen Explorers outrun the 500s, and sometimes the 500 HOs.
If the motor is fairly fresh, you probably need to rejet the carb.
Start with a simple new plug and filter, then get the main jet and needle clip setting dialed in. You obviously have "Tuning Issues"
Good luck
Old May 16, 2002 | 11:07 AM
Thor's Avatar
Do you have oversized tires? They will shave a good 5mph from your top speed.
The EBS clutches will also shave a little off of your top speed I have heard.
As MegaCrash indicated, the first thing to do is dial in you carburetor. Before you tear it all apart try tweaking the air screw in 1/8th turn increments. This can make a 5mph difference on the top end when dialed in right. Good luck. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 16, 2002 | 10:31 PM
Thanks for the help guys. I haven't had a chance yet but ill try those items listed above including setting up my oil pump....
thanks
Old May 16, 2002 | 10:33 PM
PS. Thor i am running the kenda bear claw 25-10-12/25-8-10
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Gwolf228
Feb 18, 2017 01:36 AM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
