Warrior is missing, need help
Old May 16, 2002 | 09:24 PM
KJMAXXX's Avatar
My warrior started missing the 2nd day at Siver Lake. The first day it was scream'n, then all of sudden the second day it had a bad miss/sputter. But only at full throttle. At 3/4 throttle it was fine but at full throttle it would keep cut'n out. I didnt run through any water and we took the carb and gas tank apart and cleaned everything and it still did the same thing. It also has a new plug. Need help. Any sugestions would be great.
Old May 16, 2002 | 09:53 PM
warrior007's Avatar
Run a wire from your negative terminal on the battery to the reverse lever mechanism. Do a search on that, its pretty common
Another thing to check if its a newer model is that the parking brake limiter isnt activating.. when it happens try and reach up near the clutch and push the parking brake mechanism on the clutch lever back in or forward.. sometimes if the parking brake cable isnt adjusted or is loose or missing the piece on the clutch lever wont stay against the safety switch which is the wire that goes up the handlebars to the clutch perch
95wolv
Sep 27, 2024 12:00 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
