Hydraulic clutch adjustment
Old May 19, 2002 | 03:51 PM
Alaska400EX's Avatar
Is there a special way to adjust these hydraulic clutches? I just thought I would see if any of you have messed with it, as mine seems like it could use some adjustment. When it is warming up, if you put it into gear; the quad wants to move forward with the clutch pulled in...sometimes it just dies as soon as you put it into gear.........JIM
Old May 19, 2002 | 05:01 PM
smitty911's Avatar
When mines in gear it want to pull alittle forward also, so let me know also.
Smitty
Old May 20, 2002 | 12:21 AM
MikeXCR's Avatar
Just turn the red **** on your clutch; it moves the lever away from the bars or into the bars. I am not sure if it's left or right without looking at my quad but if the quad is moving with the clutch pulled you need to move your lever away from the bars so that you get more pull. I hope this helps.
Mike
Old May 20, 2002 | 01:34 AM
Mxracer98's Avatar
Well I have a question for you guys. Where can I get mineral oil for my Hydro Clutch? Cant find it anywhere.
Old May 20, 2002 | 09:51 AM
jcv400ex's Avatar
Also, you need to change the oil on it everynow and then. I have not heard of any of them failing as well....
Old May 20, 2002 | 02:06 PM
1986atc250r's Avatar
The lower cylinder on the CD is different than the aftermarket unit sold for use on a 400EX & Raptor.... The CD's slave cyl is built into the engine case and is a bit different design, it may not suffer the same problems the 400EX or Raptor unit does.
I wonder if the problems you experienced were more related to exhaust heat from the header pipe than a design problem - if so, this is not an issue on a cannondale.
Old May 21, 2002 | 12:27 PM
I want to give a conclusion to my hydraulic clutch adjustment thread. I indeed used the little red adjuster **** at the lever to move the lever away from the bars more and it must have given me the adjustment I needed, because it is working flawlessly now. I can even sit in gear at the start line when I need to without it stalling. Anyways, everything is good, thank you for the help.....JIM
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
