Cannibal exhaust question?
Old May 19, 2002 | 08:06 PM
NittroT's Avatar
If you put on an aftermarket exhaust on a stock Cannibal do you have to do any other modifications such as any adjustments to the Feul injectors or any thing else?
Old May 19, 2002 | 09:45 PM
speedfreek440's Avatar
You will have to get your computer remapped also. You can chose between a blaze or a motto!
Old May 19, 2002 | 11:34 PM
Dex2380's Avatar
actually I beleive with a aftermarket exhaust on a cannibal you have to get the blaze or moto remap. The speed has the same exhaust as the cannibal and if you upgrade the speed you have to upgrade the map so...well you understand!
-Josh
Old May 19, 2002 | 11:43 PM
my mistake
Old May 20, 2002 | 06:32 PM
NittroT's Avatar
Whas the diffeance between the blaze and the Moto maps? Performance wise
Old May 20, 2002 | 07:37 PM
YoDaddy's Avatar
They have different power curves. I haven't ridden a moto or blaze, so I don't know exactly what the difference is.
Some aftermarket companies like Trinity will probably be coming out with some "custom" maps. I think they use a completely different map for Jeremy Schell.
Old May 20, 2002 | 08:47 PM
KNOWSALOT's Avatar
The Facility
I use a custom tailored map as well and I didn't even have him add the extra grand to my rev limit either.
Old May 20, 2002 | 09:07 PM
Sandgod's Avatar
I need rpms for the dunes. What mapping would I need Knowsalot?? I will race mx also, but all of my riding is done in the dunes so I need revs...
Old May 20, 2002 | 09:33 PM
KNOWSALOT's Avatar
The Facility
The Moto map.
Another thing you may want to try is alter your gearing.
Get another set of sprockets and chain at a higher ratio for duning. The Cannondales have more than enough power to pull taller gearing.
Just change them around as needed. 30 minutes of preparation before a ride is nothing when it gives you the results you are looking for.
The rear sprocket is the same as used on the 250R/300EX/400EX, so there are plenty of sizes to choose from.
Old May 20, 2002 | 09:39 PM
Sandgod's Avatar
I put those Raptor Dunlops on and the gearing is a bit short, because the tires are smaller then the stock Holeshots.. I'll try the gearing thing. Maybe a 14 on front.....
