ex kickstart
Old May 22, 2002 | 03:03 AM
phaskell's Avatar
i know its beent alked about before but here it is again
can i make my ex a kickstart like a xr400??? and if so hoe do i do it?? and has anyone ever done it
Old May 22, 2002 | 03:46 PM
ltracerx's Avatar
Why would you want to?
Old May 22, 2002 | 05:08 PM
Thrust's Avatar
Why in he\\ would you want a kickstart over electric?
Old May 22, 2002 | 05:45 PM
CoryB's Avatar
For one thing, you'd have a way to start it if the battery died while you were out riding...
Old May 22, 2002 | 05:57 PM
Thrust's Avatar
No,you could still jump start it.
Old May 22, 2002 | 06:11 PM
250rampage's Avatar
This has been discussed many times before, and it would be very expensive to do. You'd have to get a new sidecase, gearset, kickstart assembly, figure out how to mount the kickstarter so it can kick full swing. I have heard of people making electric start XR's with EX parts before, and anything is possible with the use of the almighty dollar.
Old May 22, 2002 | 07:44 PM
ltracerx's Avatar
It would be pointless. Why bother, all your going to do is make yourself tired kicking over the thumper and lose maybe 5-10 pounds which isn't all that much unless you're of the drag racing type, but if thats the case you're on the wrong machine!
Old May 22, 2002 | 07:51 PM
250rampage's Avatar
Yep. From what i've read, you can't keep both, it's either one or the other. Something to do with the flywheel/stator I think. Either way, don't worry about it too much. The same amount of weight can probably be lost off the rider if you're anything like me. You can also ditch some more weight with a PB blockoff, aftermaket pipe/bars, front bumper, ect...
Old May 22, 2002 | 10:13 PM
phaskell's Avatar
i am alomst posative all i will need is the xr sidecase, kickstart assembley and kick start gear. tha should be it
the ill take off the battery. starter motor and the starter gear. i bet all that adds up to 15-20 pounds easy and should only cost me around 600
Old May 22, 2002 | 11:58 PM
ltracerx's Avatar
Yea, then you add the gear and kickstart, and you've only lost 10 pounds. Cheaper and easier to call Jenny Craig!
