Performance Kit Problems
Old Mar 6, 2000 | 05:13 PM
Stump's Avatar
I installed the HL Performance Kit(pipe,jet kit,k&n)on my 99 450S. It seemed to me to be running stronger and quicker. Well one of my friends has one just like mine minus the kit. He out run me in a "drag race" every time yesterday. Start off in 2nd run until we shift into 5th then stop. I rode his thinking it was a weight difference and the same happened. his bike out run mine. The only thing I did first was take mine in for the "Honda Service" then installed the kit. Before he would get me by just a little because I weighed(past tense)100lbs more, now it seems to be worse....What is going on here ? Is something not setup correctly. I should be taking him by what he getting me !!
Old Mar 6, 2000 | 09:54 PM
Tree Farmer's Avatar
What does reading your plug tell you?
Even if you're set up correctly, the mods you've made may only enhance the top end; your drag races may not be long enought for your "advantage" to come into play . . .
Tree Farmer
Old Mar 7, 2000 | 08:49 AM
Stump's Avatar
The plug is black. I'm getting another plug today to see what happens. Even top end he still takes me worse than when I was stock. I was under the impression that the mods I made should give me bottom to mid range torque and a better throttle response ?
Old Mar 8, 2000 | 12:09 AM
thumper4x4's Avatar
Old Mar 8, 2000 | 12:10 AM
thumper4x4's Avatar
Sounds too rich to me, I would find out what the stock jet was, and what they put in it. If they went up like 3-4 sizes with just a pipe and a K&N your definatly rich...
Hope this helps
Old Mar 8, 2000 | 12:44 PM
DunePilot858's Avatar
If your plug is reading black your running way too rich. No wonder why your getting beat. Have someone set up your jetting and I bet you'll walk all over him day and night.
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Jul 15, 2015 02:07 AM
