Lakota
Old Jun 13, 2002 | 04:51 PM
bigbad400's Avatar
I'm going to be repplacing the valves in my lakota and was wondering if i need to replace the valve springs or are they reusable? And i was talking to a guy and he said i need to replace the oil seals in there or something.
Old Jun 13, 2002 | 05:08 PM
sickmojave's Avatar
if your not going to change cams the springs should be fine.and yes it is always better to change the valve guide seals when you have it apart
Old Jun 13, 2002 | 06:48 PM
gaff's Avatar
bigbad400,
On the lakota even with a FST or web cam no heavier springs are required. From dennis kirk buy the moose top end gasket kit, has every thing for $25.
If you think your springs are shot for any reason let me know, I'll send you some .010" shims for them.
Old Jun 13, 2002 | 06:53 PM
eRAPTOID's Avatar
Might as well put a cam in it while you're at it. Especially if you don't have to replace the springs. I would.
I also have a 99 Lakota, tricked out pretty good (on the outside) no internal goodies tho!
Old Jun 13, 2002 | 11:41 PM
bigbad400's Avatar
Gaff what are shims? How will i know if my springs are shot?
Raptoid i would but i want a 400ex and i don't want to dump alot in my lakota and then get rid of it. I'm going to get my dad to fix the motor. I'm going to put douglas 190's on it with razor tires all the way around. And new plastic, set of renthals and dg front bumper. Then i'm going to put it for sale maybe 3500obo. Plus it's got like 2 years on the extended warranty the isn't worth a nickle. I plan on haveing all the parts up above by the end of the month.
Old Jun 16, 2002 | 11:15 PM
bigbad400's Avatar
And my dad says he don't know if he can put the valve seats in it have you are anyone else ever done it is it. Will i have to put new rings in it after i take the head off?
Old Jun 17, 2002 | 09:16 AM
gaff's Avatar
You won't need the shims, The valve springs will be fine.
You can get a wiseco piston kit for less than a $100 and boring will be $50.
You shouldn't have to replace the valve seats, but the valve seals. Then just lap the valves in. It's going to cost you about $200 total.
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
shockwave
Aug 20, 2000 07:57 AM
cstark
Oct 15, 1999 01:45 PM
