P 650 Fuel?
Old Jun 15, 2002 | 10:48 AM
Chuckybrown's Avatar
What kind of fuel do you run? I run regular unleaded in mine...wondering if I should go to a higher octane fuel?
Thanks!!
Chucky
Old Jun 15, 2002 | 11:22 AM
2fat4moto's Avatar
I use chevron 93. Chevron seems to work best in carbs.
Old Jun 15, 2002 | 11:30 AM
gtchief's Avatar
I use 93 from wherever. If you look under the seat they recommend nothing less than 91.
Old Jun 15, 2002 | 11:40 AM
......and i wondered why mine would not wheelie real well...........
Old Jun 15, 2002 | 08:58 PM
Chris142's Avatar
Where are you guys getting the 93 octain? Is it straight out of the pump?The best we can get here is 91 @ $1.80 unless we buy race gas @ 4.50 a gallon.
Old Jun 16, 2002 | 12:10 AM
gtchief's Avatar
I get it straight from the pump. I'm pretty sure that some places only have up to 91.
Old Jun 16, 2002 | 01:16 AM
alltoys's Avatar
I use regular gas with octane booster and some transmission fluid because gas is dry the light oil adds some lubricity as it is consumed. Also a little 2 stroke oil works fine. I have used this combination for years even on lawn mowers and pretty everthing that runs on gas. IN the car I use trany fluid about a half letre or half quart every second fill up. I have never had to have the injectors cleaned even after 400,000 miles. Works and runs excellent.
Old Jun 16, 2002 | 09:38 AM
Bonza's Avatar
I run Aviation fuel in many of my home implements, including the P650. I have a tank here at home storing it for the airplane. I buy it from a local fuel distributor and the last I paid was $1.77/gal.
100 LL is such a clean fuel. Carbs stay cleaner, engines start better, and there is some lead for valve lubrication. The 2 stroke engines that are not used often, chain saws, weed eaters, etc. fire right up. When the fuel evaporates, it leaves no residue like regular fuel does.
Finally the smell is less irritating. Especially when running something like a chain saw where you are near the exhaust and not moving.
In the Prairie, I have had guys say "What are you burning in that thing!!?" I never worry about detonation.
Go to the local airport. They should be able to fix you right up.
Bob
Old Jun 16, 2002 | 01:37 PM
Elrancho's Avatar
IF you want to run a bit of two stroke oil for a high stress 4 stroke motor I'd really recomend about 3% klotz, it doesn't FUD UP your tuning or carbs at that level and does help valves and rings a bit, not plain weedeater oil.
Old Jun 16, 2002 | 02:01 PM
Wolley's Avatar
<< I use 93 from wherever. If you look under the seat they recommend nothing less than 91. >>
The recommendation for 91 is referring to the RON number. What you see on the pump is RON+MON/2. It goes on to say in the owners manual that using the average of the two, 87 octane is all you should need. I've never noticed mine pinging on regular 88 octane fuel so I don't think spending the extra 15-20 cents per/gallon for super is worth it. Higher octane fuels won't get you any more horsepower.
Go here for information about octane and what it will and won't do. There's some good links at the bottom of the page.
For the guy running aviation fuel in his 650. You're right avgas burns cleaner than autogas but it has lead in it and the additives in conventional auto oils are not designed to be run in an engine running leaded gasoline. You may end up with a situation similar to what Mobil got into with the additive package in Mobil1 wreaking havoc in aircraft engines that ran leaded avgas. Just a thought!
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
