reverse engages in 4wd - NOT 2WD - HELP!
Old Jun 22, 2002 | 06:18 PM
jtrundle's Avatar
I have a 97 scrambler 400 4x4. It will not engage in reverse in 2wd, but it will in 4wd. I replaced the clutch buttons and that wasn't it like the dealer thought it may be. Any ideas?
Old Jun 23, 2002 | 06:15 PM
BayouBlaster's Avatar
J, how old is the belt on your bike?
Old Jun 23, 2002 | 06:51 PM
I was just told that if you haven't already, you need to look at all of the connections at the reverse overide. Make sure that none of the wires have worked themselves loose. Also check under the hood for any loose connections coming off the board and the ones connected to the indicators. Sometimes if you cover any of these connections with mud, they can give you problems. It may just be a corroded connection too. It does sound like a possible electrical problem now that you know the buttons aren't to blame and assuming your belt is good.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
flyin-lowe
Dec 1, 2017 03:18 AM
r1pilot83
Sep 27, 2015 07:38 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
