EPI Springs P650 !!
I have just completed 100 trail miles on my P650 with the black secondary EPI springs installed. Even though I purchased the red primary, I decided to try this configuration first and see what the results were before instaling the primary red spring. I am so far very happy wih the black spring, it turns the 26" ITP589's with a lot more torgue with no hint of belt slippage on hills, mud and towing which is what I was after. The following is the spec for both the standard spring and the EPI replacement:
Stock: 90lbs and 195lbs @ 21/2" and 1 1/4"
EPI : 115lbs and 220lbs @ 21/2" and 1 1/4" (PN KSS3)
There will be higher engine speed and a lost of top speed with this set up but this is insignificant compared with the results achieved. I probably will not installed the red spring. Thanks to those that have brought this topic up, I am very satisfied with the results.........MJSTX
MJSTX...I am going to order the red and black spring from EPI today. From what I read here, the black spring is what I am looking for. I would also like to be able to come out of the hole harder and that is why I want the red spring. Why are you not going to use the red spring?
Iron Bear...The springs are not on the EPI web site. I ordered their catalog a while back and ordered the red and black spring for my 650 today. I also plan on modifying my muffler on Friday.(I am going to do the same thing nyroc did)...and maybe one of these days, when it is available, I am going to get a cdi box from Diamong G (1BEARMAN).
Ironbear, here is some info for you about Erlandson Performance. Their phone number is 218-829-6036.
Here is the part numbers for their springs.
Secondary spring-Black-------part no. KSS3
Primary springs--red---------part no. DRS12
orange------part no. DRS13
yellow------part no. DRS14
purple------part no. DRS17
orange H.D.-part no. DRS15
green-------part no. DRS16
Hope this helps.
Encore 454, I did the muffler mod on Saturday. I drilled six 1/2 inch holes through the four baffles and cut the spark arrestor out of the end cap, making the exhaust outlet 1 1/2 inches in diameter now. If you are going to use your 650 for hunting, don't plan on sneaking up on anything if you do this mod! Also, you need a 1/2 inch drill about 18 inches long to do this. I noticed I have more bottom end now that I have done this mod.
Hope this helps.
Ironbear...I talked to the tech guy at EPI and he told me the red spring only brings the engagement up about 500rpm...
Mastrblastr...A lot louder? Think I should drill smaller holes? Or maybe just 4 holes instead of 6? If you were still stock would you do it over?
Encore, If my quad was still stock, I would do the mod again. I actually like the way it sounds. It is way throatier now. If you are concerned about noise, I would still drill the six holes like I did, but maybe leave the spark arrestor in the end cap and try it that way first. I didn't think of it when I took my arrestor out, but if a guy is careful with a die-grinder, you could get the arrestor out without wrecking it. That way, if you find it is too loud, just weld it back in.
Alltoys has access to a dyno, and says he got a 10% increase in horsepower with this mod alone. I sure noticed it as soon as I took mine for a ride after I modded it. Good luck with your mod!! It is a pretty easy way to gain about 5 horse.
