Warrior wont crank
Old Jul 4, 2002 | 04:54 PM
ohhman's Avatar
Hi all!! My friend has a '94 Warrior thats been sitting for a couple of years. We changed the gas and put a freshly charged battery in it before we tried to start it. When I push the starter button nothing happens nor do the neutral or reverse lights come on. However, the head lights work. Whats up?? The battery IS properly connected, could there be a bad fuse or something? Where is the fuse holder located?? Thanks for any help!!
Old Jul 5, 2002 | 12:43 AM
ohhman's Avatar
Any body???
Old Jul 5, 2002 | 01:08 AM
blazenwarrior's Avatar
i am new at this but yea it could be a fuse. look for it under the rear left fender. it might have blown after putting new battery in, our after trying to maybe charge the old battery.i hope this helps.
Old Aug 22, 2002 | 11:28 PM
turbomitch's Avatar
You should also check to see if you ground to the frame and engine are good. The Warrior starter is only grounded by being bolted to the engine, if the ground to the engine is not solid it will not crank. You can ry connecting a jumper cable from the battery directly to the starter post. If it carnks your starter rely is bad.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
Bernhard
Sep 25, 2015 12:45 PM
