Fox Struts
Old Mar 13, 2000 | 11:20 PM
PolarisRacing's Avatar
I was thinking about putting on those after market Fox Struts for my 95 scrambler. I do lots of jumping and the stock struts just are not the ticket. Any comments or suggestions
Old Mar 14, 2000 | 07:20 AM
JWC's Avatar
JWC
I called Fox shocks and the guy I talked to was just promoted from Bicycles. And didn't have a clue. I was looking for some to fit my 98 explorer 400.
Old Mar 14, 2000 | 08:38 AM
JNB_Sport400's Avatar
I'm also looking for something for my 99 Sport 400
JNB_Spot400
Old Mar 14, 2000 | 09:02 AM
A400L's Avatar
As far as I know right now you can only get the non-adjustable rebuildable ones ($260 per pair from Hot Seat). They are an improvement over OEM, but not quit as goos as the fully adjustable ones.
The fully adjustable ones with remote reservoirs are'nt available anymore, for some reason. Unless you can find a used pair, but I'm sure after using them nobody would want to get ride of them and go back to stock.
Try new springs first, they're a lot cheaper.
Old Mar 14, 2000 | 07:01 PM
Mike Chero's Avatar
I have a pair on my Sport. Let me say for jumping they are much better than stock. They feature compression dampening that the Sachs or other originals lack. They really make the most out of the limited front suspension (6.25") by slowing down the down the impact of the landing. Instead of using the springs as the stock struts do, the Fox struts use dampening and the springs to absorb the bumps. The result is a slightly stiffer ride but well worth it when it comes to the rough stuff at high speeds.
Old Mar 14, 2000 | 09:38 PM
MNXPLORER's Avatar
You can get Fox struts straight from polaris they are in the 2000 accessory catolog.they are 129.99 each and available for all non Sachs machines.
Old Mar 15, 2000 | 09:40 PM
I found some Fox Shocks w/resivore on it-which is what I wanted at www.choppercity.com. But they were $300ea which in rediculous. I can buy a PAIR or aftermarket Fox gas shocks for $260. What are the advantages of the $300 ones?
Old Mar 15, 2000 | 10:15 PM
A400L's Avatar
Before you get too excited I'd check availability of the struts first. Their stuff bears a striking resembelnce to HPD's products, hmmm.
But, the advantages of the $300.- struts is that they are fully adjustable (rebound/compression) and have remote reservoirs.
Old Mar 16, 2000 | 12:49 PM
quad_man's Avatar
They got the suspension from HPD, along with a lot of other stuff. I talked to them on the phone a while back when I saw that. They said they don't have any. They must have had some leftovers when HPD ran out.
Old Mar 20, 2000 | 01:02 PM
jim's Avatar
jim
I heard that HPD is developing another adjustable, remote resivor strut for the Scrambler w/ .75" more travel which would be 9" on the front. This was from a quad shop that deals w/ HPD. I haven't had a chance to call myself to verify so we'll see. I heard it wont be availible until fall. I'm going to wait until then to see what transpires.
Jim
jdunne01
Oct 4, 2015 10:29 AM
WilliamBos
Sep 30, 2015 08:08 AM
79hugger
Aug 30, 2015 02:21 PM
Polarisman1123
Aug 13, 2015 08:13 AM
bonanza 440
Jun 26, 2015 10:01 PM
