SP500 I fliped it......now what?
Old Jul 16, 2002 | 08:00 PM
hc's Avatar
hc
Well my time has come when you do that “no thought for the few seconds I am ridding and I flip the “99” sportsman 500. happen so quick! Only got some bad bruises.
But the sp500….well…busted the light pod (pastic is the only thing broke here), speedo ok, light still burns, bent handle bars real bad, busted the front rack,…twisted everything on the handle bars but was able to twist everything back.
Cranked right up and ran fine……..the only thing is it will not idle after the wreck, it will go dead but crank right back up if I crack the throttle.
Anyone got a clue to this problem?????
Would it be much of a job to repair and replace the broken parts????
Oh I think the bushings on the steering shaft needs replacing.
[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jul 16, 2002 | 10:33 PM
xcrider's Avatar
Check the ETC. Adjust it you probably stretched / tweaked the cable
Old Jul 17, 2002 | 12:37 AM
ftwflh's Avatar
Check the air box and filter for oil too.
Old Jul 17, 2002 | 08:27 AM
ecm747x's Avatar
Sorry to hear about your flip, at least you came out ok. As far as replacing your light pod, you will have to take the handle bars all the way off and hence unhook your brake line, which will then cause you to bleed your front and rear brakes. Then taking all the components off the lower pod and swapping them over..not a hard job As far as needing bushings, nah...they are only rubber. Sounds like you have bent the brackets that holds your rubber bushings in place. YOu will have to rebend the mount bracket and the bracket that goes around your bushing. YOu will want to take the small covering off the front to gain access to the bushings. As far as your rack. Hope you have some torqes tips. No big deal there. As far as it not wanting to start. The two previous posts have good places to start....
Old Jul 17, 2002 | 05:06 PM
hc's Avatar
hc
Thanks for the replays!
Got another question. I have been hearing for some time now that the later (200?) SP500 models have better steering than the earler models do. Like maybe the geometry was changed in the later models. If this is true!!! Can i incorporate the same steering in my 1999 Sportsman 500. Maybe buy all the components to make this change.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 17, 2002 | 05:26 PM
brent87LT1's Avatar
You don't have to remove the bars to take the pod off. You don't have to do anything to the brakes. I changed my pod in about 15 minutes with a phillips and a flat head screwdriver. Sounds like you'll be replacing the bars anyway, but you still will not have to unhook the brakes. You prob. do need to adjust the throttle & choke cables. I'll bet thats the idle problem. Also, check your oil, you probably have fuel in it.
Old Jul 17, 2002 | 07:01 PM
fourlix's Avatar
Take your handlebars off and check the mounting plate at the top of the steering stem. Often on Polarises when you think you've bent the handlebars it is really just this plate, which is easy to straighten with the handlebars off using a crescent wrench. Be carefull not to tweak the steering stem itself. This is a built in weak point, designed to bend instead of the bars or stem, and easily fixed. It will be bent in any case, but you might not have to repair or replace your bars.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 17, 2002 | 11:53 PM
ecm747x's Avatar
If your lower pod is broken, and is built the same way as the 2002 madle then the bars will have to come off. No way around it. Like I said unless your lower pod half can be split.
Old Jul 18, 2002 | 10:42 AM
xcrider's Avatar
You do not have to pull your handle bars to change out the lower pod. The lower pod has a slot under the headlight so that you can slide the lower pod around the stem. Nothing has changed with this mounting in at least 3 model years maybe more.
Go to Polaris's web site and download the parts manual. It clearly shows the assembly.
Old Jul 19, 2002 | 01:49 AM
ecm747x's Avatar
I went and looked at my pod again and I stand corrected, soory for the missinformation. Mine does have a slot, just didn't see it for the braket in the way. Sorry for the missinformation, my bad.....
Aug 21, 2015 01:46 AM
FireFighter
Jan 7, 2001 04:50 PM
BONER
Dec 13, 2000 09:04 PM
mudhog
Nov 15, 2000 11:18 PM
cstark
Sep 11, 1999 01:21 AM
