No improvement after rejetting
Old Sep 1, 2002 | 08:38 PM
Haynes1111's Avatar
I have rejetted my quad several weeks ago. I ran it against some quads I have always raced in the past. It ran fine thru out the full trottle race ( no boggy, flat spots ect. ) except I did not pick up any speed. Today I played with the fuel mixture screw and saw slight improvement running it in my yard. I will be getting my Carbtune II kit to synchronize the carbs this week. I have 132 front and 136 rear jets from Dynojet. From reading posts I see my jets size is higher then most everyone else. What else can I do to get more speed. Higher jets? Lower jets? Any help greatly appreciated.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 2, 2002 | 08:15 PM
STAKK's Avatar
Top speed is held back due to the stock CDI, until Diamond G releases there's it won't climb any higher.....
Old Sep 2, 2002 | 09:33 PM
Haynes1111's Avatar
But I'm no quicker to max speed either.
Old Sep 3, 2002 | 06:26 PM
Haynes1111's Avatar
back to the top
Old Sep 3, 2002 | 08:29 PM
NovaKaw650's Avatar
All you can do is keep experimenting with the jets and needle heights. If it runs smoothly but still seems down on power, I would go richer.
Old Sep 15, 2002 | 12:03 AM
Haynes1111's Avatar
I lowered my jets today from 132f/136r to 130f/134r. I kept the needle on 4th notch. It seems much quicker. Next weekend I will run it againts some old foes. Air screw out 3 1/2 turns. I also replaced those terrible screws that everyone strips out with new ones with ellen heads. Should make the job much easier if I ever have to re-jet again. I believed I could have re-jetted without removing anything if it was'nt for those soft brass screws which keep on stripping on me.
Old Sep 15, 2002 | 12:22 AM
Haynes1111's Avatar
I forgot to say I also synchronized my carbs today
Old Sep 15, 2002 | 11:47 AM
650vtwin's Avatar
Haynes,
I also noticed a slight improvement with the 130f and 134r over my current 132f, 136r (4th notch, 3 turns out). The problem I had with the smaller jets was that my spark plugs were not changing colour. I had to go to the 132f and 136r before I got a nice light brown colour. Have you put new plugs in, and checked them since you lowered the jets?
Old Sep 15, 2002 | 08:45 PM
Haynes1111's Avatar
not yet.
Bratman2
Aug 6, 2022 01:42 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
antiguogrumete
Sep 5, 2015 03:41 AM
