Blaster low end mods...
Old Sep 3, 2002 | 08:29 PM
Peltrax's Avatar
What is the best way to get a lil more low end on the blaster.....the money should be rolling in and before i get my 240 kit,is the vitos(or pro x) piston good for all around power,same with the v-force reed valve???I love the top end power the toomey gives but want a couple mods for a lil more low end before i start gettin buckwild on the blaster!!
Old Jul 11, 2004 | 01:42 PM
silentdeath489's Avatar
Default Blaster low end mods...
I would also like a little more low end power for my blaster.
Old Jul 11, 2004 | 06:41 PM
daputz's Avatar
A long rod or stroker crank, higher compression, advanceing your ignition.....will all help with low end power. You can also change you gearing (smaller front, larger rear sprocket, or smaller rear tires).
Old Jul 12, 2004 | 08:20 PM
yamaharider200's Avatar
If u get smaller rear tires it will feel like there is more low end but it will also make the gears a lot shorter so your top speed wouldnt be very high
Old Jul 13, 2004 | 10:46 AM
ShadyRascal's Avatar
Hey Peltrax how ya been? You can pick up very noticeable bottom end power with a degree key on your flywheel. I did that on two Blasters, and it's inexpensive (get it from Vitos) and didn't cost any top end. One of them did shear though, they are not as strong as stock being offset-ground. I would say just wait for the 240 kit though. Make sure you have it ported and the head mod done to give you 165psi or better. It'll scream!
Old Jul 13, 2004 | 11:26 AM
roosthrower's Avatar
this thread was started nealy two years ago.
Old Jul 13, 2004 | 01:21 PM
Shav0's Avatar
2 years?
This thread was created on Tue September 03, 2002 8:29 PM
This thread isn't even a year old yet dude..last time I checked it was July 2004...but then again I did hit my head really hard during that crash..how long was I out?
Old Jul 13, 2004 | 02:08 PM
Aw crap, I hadn't noticed that. I think Peltrax went in the service.
Old Jul 13, 2004 | 02:14 PM
Originally posted by: Shav0
2 years?
dude. you are the retard. this thread was started september 03, 2002.
it is july 13, 2004. simple math states that this thread is nearly two years old.
Old Jul 13, 2004 | 06:54 PM
Shav0's Avatar
wow dude don't get all bent out of shape..Im jsut messin with you.
I don't really give a **** how old this thread is..
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
