1999 SP 500/ speedo doesn't work and either does the 4X4!
Old Sep 4, 2002 | 07:47 PM
slewpumper's Avatar
Could somebody give me some advice on this! A friend of mine has a 500 sportsman which the 4X4 will not engage. The speedometer doesn't work either. I thought that the 4X4 engagement is sensed by the speedometer, is this correct? What should I look for. TIA
Old Sep 4, 2002 | 09:40 PM
bjn644's Avatar
I had the same problem on my 2000, the speedometer was bad, it has a small computer in it that controls a few different functions, one of them being the 4 wheel drive.
Old Sep 4, 2002 | 11:13 PM
TrailBossKing's Avatar
Same thing happened to my 2000 mag500...the speedometer still worked fine but the 4x4 wouldn't engage... a new speedo runs for about 180 bucks[img]i/expressions/face-icon-small-frown.gif[/img] i think thats a little steep but thats all i could find and i wanted to go muddin again soon..later
Old Sep 5, 2002 | 10:33 AM
jwarden1's Avatar
hi
i have a used speedo
that came off a 1999 magnum 500
its in km not miles but it works
right now its on ebay
but if you would like it i will end the auction for 100
let me know
ebay id is jwarden
chips4sle@aol.com
thank you
jeff
Old Sep 5, 2002 | 07:18 PM
floodrunner's Avatar
If you are comfortable with electrical diagnostics, check the ground (brown wire) to the speedo before you replace it (hook up a 12v test light between the pos battery terminal and the brown wire. If it lights up you have a proper ground). The AWD went out on my ’01 HO and I traced it to that bad ground. Hot-wired a new one in and everything’s fine.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
sara durrant
Jul 6, 2015 05:32 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
