need help on top end in reverse
Old Sep 4, 2002 | 10:31 PM
HondaEXtreme01's Avatar
when i put my 300ex into reverse and give it alot of gas it seems to cutout in high rpm's. it only cuts out in reverse. all other gears run just like normal. i thought it was the choke but it was completely off and i would think if it was on it would do it in all the gears. and also i know its not the reverse clutch thing cause i have it zip tied all the way back so it is easier to put in reverse. thanks for the help.
Old Sep 4, 2002 | 11:24 PM
tprender's Avatar
You are hitting the rev limiter. It is set lower on reverse. This so that people will not go very fast in reverse.
Old Sep 5, 2002 | 12:11 AM
yeah well i guess it could be that. i just don't get it cause when i 1st got it it didn't do that it would rev all the way up and then one day it just started cutting out. the only thing i did before it started this was clean the spark plug. but i don't know i guess you could be right. it still functions and doesn't mess up anything else.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
