Stalling when hot
Old Sep 14, 2002 | 09:04 PM
QUADMXer's Avatar
When my daughters LEM Caymen gets hot it stalls. It acts like it is starving for fuel. It usually starts right back up, but won't stay running. Once it cools down it is OK. I tried running it with the gas cap off thinking that it might be a vent problem (I saw air bubbles in the fuel line from the tank to the carb), but that did not help. If anyone out there can help I would sure appreciate it. By the way, my brother in laws oddysee does the same thing and this would be helpful for him as well.
Old Sep 14, 2002 | 09:21 PM
hot_shoe_cv's Avatar
You might try installing a new plug and doing a test ride & plug read to be sure the engine isn't lean. Since overheating is a symptom of a lean condition you may already stated the problem.
Old Sep 16, 2002 | 09:20 PM
QUADMXer's Avatar
Plug is good. In fact it has fouled in the past.
Old Sep 22, 2002 | 02:58 AM
Guiness's Avatar
i ve had the same prob with my 85 ody run stall seem to ovrht start stal etc, finally tested stator and cdi box found both to be defective, runs like a champ now, contact triple e i paid $115 for stator and $100 cdi,both were bad in my case, but more than likely its the stator, if your brthr in law changed the low end gear oil he may put too much in which leakes into the fly wheel case and burns out the stator, hope this helps
Old Sep 22, 2002 | 08:33 AM
QUADMXer's Avatar
Thanks for the info guiness. How did you test the stator and CDI? Who and where is triple e?
Old Sep 22, 2002 | 12:44 PM
drag295RR's Avatar
you could have a vapor lock condition (carb problem)
Old Sep 27, 2002 | 10:48 PM
hardlydangerous's Avatar
Check the float level
check for intake leaks
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
