Vinson Engine Problems
Old Sep 16, 2002 | 09:48 PM
zukkii's Avatar
I have about 400 miles on my Vinson. The last time I ran it I noticed it was loosing power at about 1/2 throttle. By the time I made it home, it did good just to back into the truck. It idles smooth but boggs when I give it gas and if I pump the throttle, it back fires. I changed spark plugs and checked the bowl for fuel, both were OK. Any suggestions? Thanks
Old Sep 16, 2002 | 11:14 PM
95wolv's Avatar
Is it a flat slide carb,or a cv carb? If it is a flat slide,it probably has an accelerator pump,could be hung up,giving you a bad bog,leaning out when you hit the throttle. If it is a cv, could be the diaphram that lifts the slide is ripped or has a hole in it,then you get poor performance from little throttle opening. When you checked the bowl,did you spray out all the passages in the carb? just a little moisture or dirt can wreak havoc in a small passage in the carb.
Old Sep 17, 2002 | 11:38 PM
zukkii's Avatar
Thanks for the reply. However, you are talking over my head on what type of Carb. it is. I am not sure. It appears thought that my problem was that I got a hold of some bad gas. It appears to be working ok now. Thanks again for the info.
joshuafromny
Jun 22, 2015 05:30 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
