P650 Pulley Shim info
Old Sep 20, 2002 | 09:30 PM
92LT's Avatar
Here is a something I noticed about driven pulley shims for P650 owners. It's kinda hard to explain....
I went to buykawasaki.com and compared microfiche between the 2002A, 2002B, and 2003 Prairie 650's driven pulleys. I noticed that on two of the models, only 3 shims are listed. On the 3rd one, it lists four different shim sizes. So if you are ordering shims, be sure to note that there are 4 available shims, not just 3 as some microfiches show.
Old Sep 23, 2002 | 08:14 AM
trx450's Avatar
What is the 4th size?. I know there are : .6mm/1.0mm/1.4mm. I just ordered them last week.
BTW-- I installed the Erlandson "black spring"......it kicks @SS!
Old Sep 23, 2002 | 08:39 AM
DustinMinnesota's Avatar
They added the 4th during the middle of the year and your dealer has the part number for the 2002 models...However I have not seen the film on the 2003 but I bet it is the same as the 2002 part number,
Have you seen the film on the 2003? if so email the link or a copy of the carb / air box parts and the clutch parts / belts please.
Old Sep 23, 2002 | 09:38 AM
92LT's Avatar
The 4th spacer size is .8. You have to look in the 2002 650 B1 microfiche to see it.
The 2002A1, 2002B1, and 2003 Prairie 650 microfiches are all up at www.buykawasaki.com
Kawasaki must be aware that there is some sort of belt deflection problem, because it seems that new machines are coming with different deflections set from the factory.
Old Sep 23, 2002 | 10:24 AM
Thanks 92 will go see if that is what I need
Old Sep 23, 2002 | 12:36 PM
trx450's Avatar
I'll ask my friend a the Kaw dealer if there are some new deflection specs.
Old Sep 24, 2002 | 05:43 PM
mudseeker's Avatar
My dealer told me the shims range from .15 to 1.2 mm. I ordered a .5 today. I took out my last shim which was .6 and now it has a slight squawk when it's idling in gear so I hope a .5 will fix that. I also ordered the black EPI spring today so I can't wait to see how it works.
Old Sep 24, 2002 | 05:47 PM
Haynes1111's Avatar
How much are the shims?
Old Sep 24, 2002 | 06:09 PM
92LT's Avatar
Shims weren't cheap. I think I payed around $4.29 each. More/less, depending on dealer I'm sure.
Old Sep 25, 2002 | 07:50 AM
trx450's Avatar
mudseeker-- If your 650 is squealing at idle, in gear, you need a THICKER shim(s) than what is currently in place, the belt is slightly too tight. I don't think your info is right on shim range. My understanding is that there are 4 sizes to choose from: .6mm,.8mm(new for '03),1.0mm,1.4mm.
BTW-- The "black spring" KICKS A$$!!!!!
