P-650 Driven Pulley shim set........................
Old Sep 26, 2002 | 08:30 AM
trx450's Avatar
I now have ALL shims for adjusting the belt. I was "hosed" $5.40 EA. for same, but I don't have to worry about them NOT being available. I got the part #'s on <www.buykawasaki.com>.
Old Sep 26, 2002 | 11:19 PM
KISSSOFDEATH's Avatar
All I can say is make sure you measure the belt deflection right when doing it. I made two mistakes in measureing mine. One was the belt wasnt all the way up top of the driven "rear" pulley and the other was not haveing my straight edge flat on the belt located at the drive pulley. Both of these gave me false readings and caused lots of headaches. I tried using a square for the staightedge but ended up, I found a large file that worked perfect. Good luck.
Old Sep 27, 2002 | 07:44 AM
trx450's Avatar
KOD-- YEP, I learned the hard way, too. I will use a good, accurate scale to get that 13lb. force!
merryman
Jan 19, 2016 04:29 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
