explorer trans in scrambler 4x4
Old Oct 1, 2002 | 05:10 PM
turboman's Avatar
I would like to know if any one has swapped an explorer trans in a scrambler so they would have low range. Does it fit, how hard to change, and how much does it cost. Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 2, 2002 | 12:50 AM
turboman's Avatar
any one have any input?
Old Oct 2, 2002 | 01:01 AM
425Xpedition's Avatar
Does it fit?
Yes.
How hard to change?
Remove old tranny and bolt in place.
How does it cost?
It aint cheap $1500 - 2000.
The hardest parts are modifing the airbox and making a shifter work. The cost can vary depending on which parts you use and your fab skills. My Scrambler has the Xplorer tranny in it and it looks like it came from the factory.
Old Oct 2, 2002 | 01:16 AM
turboman's Avatar
425X, thanks for the info.
Where did you get your trans, and how much did it cost?
Is high range the same top speed as with the original trans?
What is the top speed in low, does the engine have a rev limiter on it so you will not blow it up?
thanks
Old Oct 2, 2002 | 02:06 PM
KEP's Avatar
KEP
You also have to change the shifter of course and the rods and I think there are some slight modifications to the electrics relating to the neutral/reverse switch on the transmission. It is a real shame Polaris didn't include the low speed from the factory, at least as an option. Old Xplorer transmissions are impossible to find, I've tried, and a new one cost nearly as much as I paid for my used Scrambler itself.
Old Oct 3, 2002 | 12:22 AM
Trans came from dealer. Do not remember the exact cost. Close to a grand, I think. Top speed is the same in high. Not sure about top speed in low. Less than 30 with the 25's. Maybe 35 with the 28's. Go ahead and try to blow up the 500. It is hard to get the motor to rev that high stock. You will not hurt it holding it wide open in low. Been there done that.
Old Oct 14, 2002 | 11:08 PM
turboman's Avatar
Default explorer trans in scrambler 4x4
anybody else?
Old Oct 28, 2002 | 01:12 AM
turboman's Avatar
help!!
Old Oct 29, 2002 | 10:43 PM
turboman's Avatar
anybody?
Old Oct 29, 2002 | 11:35 PM
turboman what else are you wanting to know?
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
