My DS anymore
Old Oct 27, 2002 | 01:39 AM
Kodiak01's Avatar
Default My DS anymore
Ok I just put a Ronwoods 11.5:1 Piston in my DS and I tried to start it up, but it wont start.....it sounds like it trying start but it wont. Also noticed when I hit the throttle and look through the Carburetor that there is black peice before the butterfly that I can push up & down with my finger, but it dont open when I hit the throttle. Is the normal, thanks
Old Oct 27, 2002 | 01:44 AM
Air's Avatar
Air
That is normal. the slide you are refering to is the slide in the carb it is controled by vacuum.
I would start checking your no start problem by checking valv timing and clearance.
Old Oct 27, 2002 | 02:09 AM
Kodiak01's Avatar
Ok, how would I go about checking my valve clearance & timing, also how do I adjust the valves, and can u give me some specs for the clearance & timing?
Thanks
Old Oct 27, 2002 | 02:24 AM
Majorecho's Avatar
check out this link for the info you need timing and valve info
Old Oct 27, 2002 | 11:46 PM
Kodiak01's Avatar
Ok thanks for the help. My timing is 1-tooth off, could this cause my no-start problem?
Note. It seems to want to fire on the exhaust stroke. (If that makes any sense)
neilbedwell
Nov 10, 2018 11:02 AM
freeman34
Jan 8, 2016 11:46 AM
scram5050
Sep 3, 2015 05:06 PM
bodatiouskid
May 27, 2015 08:33 AM
250Thumper
Jul 26, 2000 09:19 PM
