250x problem
Old Oct 30, 2002 | 12:37 PM
jescomaier's Avatar
Default 250x problem
I am having problems with my 250x. It is not wanting to idle at all, could it possibly be the jets or the filter andy suggestions would be greatly appreciated.
Old Oct 30, 2002 | 06:51 PM
300exRiderJay's Avatar
This may sound obvious, but have you checked you idle screw, or played around with it. Will the problem stop after the engine gets warm?
Old Oct 30, 2002 | 08:47 PM
liftkit's Avatar
i gonna say the same thing that 300ex said. your idel screw might need adjusting. i have that same question he had though, is it just cold shouldered or did this problem just occour one day? need more info.
Old Oct 31, 2002 | 11:17 AM
jescomaier's Avatar
I have checked the idle screw. It idles only when it's cold, once it is warmed up then it doesn't idle at all. I am constantly having to give it gas , if you are not on the throttle it will die.
Old Oct 31, 2002 | 08:26 PM
reconbasher's Avatar
i think that what your problem might be in the jetting but im not 100% sure though. i think this might boil down to one of the tech gods
Old Oct 31, 2002 | 10:08 PM
Crawdad's Avatar
Sounds like a sticky choke maybe.
Old Nov 3, 2002 | 09:53 PM
crash101's Avatar
yea i know what you mean i have a 250x when its cold it will idle but when it warms up it wont idle for aything. I can be ridding and i slow down and it will die. messing with the carb screw helps a little but the jets make sence
Old Nov 4, 2002 | 05:29 PM
twitchell's Avatar
Does it pitter and putter and stuff when you slow down and kinda smoke? If it does its the choke and its flooding it . try messing with the choke is probably stick like the other guy said.
Old Nov 5, 2002 | 02:56 AM
PaulV's Avatar
HAVE YOU CHECKED YOR PILOT SCREW? SOUNDS TO ME LIKE IT IS TURNED OUT TOO FAR.
TRY TURNING YOUR PILOT SCREW ALL THE WAY IN, THEN, BRING IT BACK OUT 2 AND A HALF TURNS. THEN ADJUST Y0UR IDLE WITH THE IDLE SCREW. HAD YOUR QUAD BEEN SITTING FOR A WHILE? IF SO YOUR CARB MAY JUST NEED TO BE CLEANED. HOPE THIS HELPS.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
