400 counterbalence oil
You check it by unscrewing the dip stick on the back side of the engine.You have to pull the air box to get to it with a screwdriver.Then drain it underneith.It will take a long funnel to get the oil in it.
my engines is performances oriented (modded) and i run amsoil 0-30 heavy duty synthetic motor oil in the counter balance,DON'T add more oil (just 3 oz) is enough,if you add too oil in the counter balance,i got some test showing the engine still pull without the trigger on (too high engine lubrication) and it is very embarassing...
when the oil turn black it is time to change it as well.
i mean too excess oil in the counter balance (trough the dip-stick)
a too high vicosity get my engine producing enough power to pull your arm at idle-1/8 (4000-5000 rpm),i've made a mix of energy release stuff and amsoil heavy
duty motor oil,no wear at all in the engine,i run the wiseco hot rod.
cwbond007
Dec 20, 2020 05:48 AM
