400 counterbalence oil
Old Nov 3, 2002 | 06:31 PM
vig's Avatar
vig
Default 400 counterbalence oil
Where is the counter balence oil and how do I check it? What type of oil does it take? I had no idea the 400 2stroke had any oil in the crankcase.
Old Nov 3, 2002 | 07:31 PM
2manytoys's Avatar
The drain plug is underneath by tha starter drain. It will take about 3oz (not alot i know)of 10w30.
Old Nov 3, 2002 | 10:14 PM
ftwflh's Avatar
You check it by unscrewing the dip stick on the back side of the engine.You have to pull the air box to get to it with a screwdriver.Then drain it underneith.It will take a long funnel to get the oil in it.
Old Nov 4, 2002 | 06:12 AM
modquad's Avatar
I've had really good luck running Mobil 1 synthetic. Like the others said, doesn't take much, so a quart lasts a long time.
Ken
Old Nov 5, 2002 | 02:21 PM
scramblered's Avatar
my engines is performances oriented (modded) and i run amsoil 0-30 heavy duty synthetic motor oil in the counter balance,DON'T add more oil (just 3 oz) is enough,if you add too oil in the counter balance,i got some test showing the engine still pull without the trigger on (too high engine lubrication) and it is very embarassing...
when the oil turn black it is time to change it as well.
Old Nov 6, 2002 | 12:51 AM
DaveRuane's Avatar
what were you trying to say about too much oil in the counterbalance? My understanding is that excess oil flows over into the crankcase...
Old Nov 6, 2002 | 11:22 AM
i mean too excess oil in the counter balance (trough the dip-stick)
a too high vicosity get my engine producing enough power to pull your arm at idle-1/8 (4000-5000 rpm),i've made a mix of energy release stuff and amsoil heavy
duty motor oil,no wear at all in the engine,i run the wiseco hot rod.
cwbond007
Dec 20, 2020 05:48 AM
chsimpson217
Jun 21, 2009 07:18 PM
tripd
Jun 19, 2009 12:06 AM
patrickvol1
Nov 22, 2006 09:59 PM
TINKERMAN
Mar 8, 2004 03:35 AM
