wheel spacers for mojave?
Old Apr 3, 2000 | 08:43 PM
nikbrew's Avatar
are the 1 inch front.rear wheel spacers any good? they are alot cheaper than a wider axle/a-arms. Do they break? i need to widen the back so it will stop hitting my dg exaust. also, the dg exaust has no clamp for the head pipe and it comes undone sometimes, should i put a pipe clamp on it?
Old Apr 3, 2000 | 11:54 PM
JD250R's Avatar
I have a DG steel pipe on my 1987 Mojave, it to hit the rear tire. What clamp are you talking about? Don't use wheel spacers because it puts too much stress on the spindels and wheel bearings. Just do a search for wheel spacers.
Old Apr 8, 2000 | 08:12 PM
mojo's Avatar
I had the same problem with mine. To correct this I unbolted the pipe and moved the hanger to the inside of the frame and put the bolt in from the inside.I also needed a couple of washers to push it further. This moves the pipe in further and now mine doesnt hit anymore.Cheap fix compared to a new axle.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
