Wench
Old Nov 30, 2002 | 11:15 AM
sly's Avatar
sly
Default Wench
My wench has lost all its power, It will run but has no pulling power. Has anyone had this happen to theirs? and what was the cause.
Thanks SLY
Old Nov 30, 2002 | 11:28 AM
Win3855's Avatar
Default Wench
Whats a wench? If you mean winch, check your battery connections for dirt and or corrosion.Your swich may be only passing half the juice to winch motor.
Old Nov 30, 2002 | 04:35 PM
mudcat47537's Avatar
Default Wench
It may be time to take it apart and give it a good cleaning and regrease.
Old Dec 3, 2002 | 10:26 AM
sxr6's Avatar
Default Wench
Sounds like 1 set of points is sticking. Pull it apart & give it a good cleaning.
Old Dec 4, 2002 | 08:12 PM
shooter29's Avatar
Default Wench
Do you use your winch to secure your atv while traveling? I had a problem in the past where the winch sounded like it worked but did not pull. It was a Warn #2000. I used to use it to secure to the trailer. After talking to the Warn rep., he told me to take the housing off the right side (right side when looking at the winch) and check the gear inside. Sure enough the gear on the plastic housing was stripped. The rep said this was a common problem when people use the winch to secure to the trailer, the jarring caused by the trailer bouncing when traveling puts extreme stress on the plastic housing and can eventually wear it out. I ordered a new housing, had a simple replace, and was back in business. Good luck.[img]i/expressions/face-icon-small-smile.gif[/img]
whitty
67
Feb 24, 2021 02:52 PM
Donnaaaaaaaaaa....
Oct 31, 2007 01:45 PM
sianod
Feb 18, 2007 09:51 AM
ewalden
Jul 21, 2006 07:33 PM
Shifty
May 7, 2002 10:24 AM
