45mm Carb ??
Old Dec 3, 2002 | 01:12 PM
BIGBAJA's Avatar
Default 45mm Carb ??
What kind of increase in power will I get? Mods listed below.Thanks in advance[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 3, 2002 | 02:36 PM
Eaglecollector's Avatar
I went from a DJ 190 with K&N in the box to a 45 with K&N carb mount and WOW!! I was very, very happy. And I am sure that you will be also. Excellent investment.
Old Dec 3, 2002 | 02:50 PM
bombrider's Avatar
Did you tune the exelorator pump yourself?
Old Dec 3, 2002 | 02:56 PM
Yes I did. It was actually real easy. On mine I have a slight cap between the pump shaft and the white plastic cam lobe. I would say about 1/8 to 3/16 of an inch gap. That got rid of the flat spot everyone talks about. So far so good. I am very happy with it and the new found power[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 3, 2002 | 03:38 PM
bombrider's Avatar
How much did you spend on the carb?
Old Dec 3, 2002 | 06:06 PM
I got the kit from RWR for 645 I think it was. It came with the carb, Accel. Pump, Intake Boot, Ported intake Manifold, Twist Throttle w/ cable and some Scott grips. You can get it with the Tumb Cable if you want for a little less money to.
Old Dec 3, 2002 | 10:58 PM
Bom2000's Avatar
Does any one have a part number for jets for the TM45 on dennis kirk??? THanks in advance
Old Dec 4, 2002 | 08:44 AM
SANDMAN430's Avatar
what is the dead spot in the bottom that i hear about? i'm to the spot that i need a larger carb, but the dead spot thing has me wondering whats up
Old Dec 4, 2002 | 09:57 AM
02BAJA's Avatar
I dont know if I want to say anything because I may want it for myslef. But............there is one on Ebay right now for $300 starting bid price and no reserve.
Old Dec 4, 2002 | 10:00 AM
What it is, Is if you wack the throttle really fast it will hesitate for just a sec. But if you roll on the throttle (even fast) there is no problem. If you install the accel. pump that comes with it (tell them you want it) and adjust it correctly there is no hesitation.
