Difficult to get 650 to shift sometimes
Old Dec 7, 2002 | 02:21 AM
pcpacker's Avatar
Default Difficult to get 650 to shift sometimes
Can any of you tell me why sometimes I have to rock back and forth to get my shift lever to move into a gear? I doesn't happen all of the time, but when I does, I feel like I am rocking and forcing the lever into place. It isn't always the same gear either.
I have heard mention that there is a shifter adjustment that can be done, but when I did a search for this, there were no hits.
Old Dec 7, 2002 | 03:13 AM
RockyQuarry's Avatar
Don't worry about it, there are no syncros inCVT ATV's as in cars. Sometimes you have to roll it a bit to get the gears to mesh. You should ride some other bikes when you get the chance and compare them.
Old Dec 7, 2002 | 09:35 AM
NovaKaw650's Avatar
Turn the idle speed up a little and the balky shifting will be history.
Old Dec 7, 2002 | 09:36 AM
nyroc's Avatar
PCpacker, some people are able to get just a little teeny bit of pressure on the belt going by turning the idle up. This makes the gears clack just a little while shifting, but the shifter never hangs up like that.
Also, if the belt is adjusted tighter, there may be enough belt pressure to make smoother shifting whether the the idle is turned up or not.
You should not adjust the shifter for this. Usually the shifter needs adjusting if it does not properly engage low range, which generally causes a ratcheting sound as the gears slip when slowing down in low range.
Old Dec 8, 2002 | 08:08 AM
Steelhead650's Avatar
I've noticed lately that i can shift right from low to reverse, Since The blk spring . anyone else noticed this.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
