another 400ex jetting question!
Old Dec 29, 1999 | 11:54 PM
Jeaner's Avatar
Can you get to the needle jet via the main jet access on the bottom of the carb? If not where abouts is it located.
PS they might as well not even sent directions with the jet kit, the only thing they show you is where the fuel mixture screw is!
Thanks!
Jera '00 400ex
Old Dec 30, 1999 | 03:20 AM
hot_shoe_cv's Avatar
Jeaner,
You have to remove the top of the carb, the slip the slide out which contains the needle
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Dec 30, 1999 | 09:06 AM
Jeaner's Avatar
Thanks, i found a couple of pictures on the web and i thought it looked like it was out of the top, but know i know for sure.
thanks again, i've got my new e-series slip-on yesterday along with a jet kit and som outerwears. i also drilled 5 1.25 inch holes in the airbox lid I'M READY
Jera '00 400ex
Old Dec 30, 1999 | 11:58 AM
Guest
Guest
Posts: n/a
Can you give me those addresses on the web so maybe I'll be able to figure this out my self? Thanks.
Old Dec 30, 1999 | 02:22 PM
Jeaner's Avatar
www.icnetx.com/speed/jet.html
Old Dec 31, 1999 | 03:33 PM
theowl's Avatar
Use caution when you remove the needle from the top of the carb. Any damage to the parts in the carb is EXTREMELY expensive. Voice of experience. Good luck.
Old Jan 1, 2000 | 06:01 PM
Jeaner's Avatar
Well i failed to get to the needle. i could not back the carb out far enough from under the gas tank to get the top off. i did up the main to 165 and it really helped it pull very hard in any gearif you wanted to punch the throttle.
Jera '00 400ex
Old Jan 1, 2000 | 07:49 PM
feara400's Avatar
When you TRY to get to the needle, there are two VERY small screws that hold the needle in place. The heads to these screws take a phillips-head screwdriver to remove them. They almost always strip out. Be sure to use the right size screwdriver and use LOTS of pressure. Also, don't waste your money buying the Dynojet carb kit. There is no real difference in performance. You would be better off jumping up your pilot jet one size, adjusting your air/fuel mixture screw, open up your airbox (read: remove the lid and save it for winter and extemely wet riding), and changing your main jet. You will need to go up to about a 160-170 without the lid depending on elevation or you will need about a 150-155 main jet with the above modifications with the lid on. You can also raise your needle with a super small washer (like the one found on points) or change the setting of the e-clip to the 4th notch (counting from the top down as the needle points down). This will help accelleration a little but the change may not be worth the pain involved in getting to the needle. These mods will definetly work on a 2000 model, since the stock main jet is a 148. I am not sure the exact main jet is required for a 1999 model because the stock main is a 140. Now you have the info-----Good Luck!
Cole Hadden
Jun 15, 2025 09:05 AM
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
yambam13
Jul 4, 2015 01:49 PM
