Shaved Fenders.....need pics!!!
Old Dec 16, 2002 | 04:31 PM
BajaDS650's Avatar
Default Shaved Fenders.....need pics!!!
I have an extra rear fender and it popped into my head that I should shave them for when I go duning, and just use the other one when I want/or need to.
Anyways, just wondering if you guys could send me some pics of what yours looks like. Also how should I do it?? Thanx for your help.
Old Dec 16, 2002 | 04:49 PM
DemonDS's Avatar
Check out the gallery, you can see most everybodys on there and save you the time and them the hassle of email.
Old Dec 16, 2002 | 06:22 PM
VEGAS650's Avatar
Believe it or not, I cut mine with a utility knife.
I admit, I'm a floor covering installer, so I'm pretty good with the knife.
First I just followed the line on the back of the fenders. That gets rid of a lot of excess, then you can shape it the way you want.
I will have pictures with my new paint job posted by the end of the week.
Old Dec 16, 2002 | 06:37 PM
imported_juggalo's Avatar
i used a utility knife to cut my front plastics. works good.
Old Dec 16, 2002 | 07:14 PM
BajaDS650's Avatar
Didn't find too many DS's with shaved fenders in the gallery. Can anyone help??
So a utility knife is the way to go, or is there something else?? For some reason a dremel tool came to mind??
Vegas650: When you say you followed the line on the back of the fenders, do you mean the 'lip' around the edge??
Old Dec 16, 2002 | 07:23 PM
lilnotts's Avatar
look at dsaholics or at majorechos
Old Dec 16, 2002 | 07:32 PM
BajaDS650's Avatar
Thanx lilnotts. I like how Majorecho's looks.
Has anyone had a problem with not having any heelguards??
Old Dec 16, 2002 | 08:04 PM
lilnotts's Avatar
no problem, and i think dsaholic should know, he seems to be able to get some big air
Old Dec 16, 2002 | 08:31 PM
VEGAS650's Avatar
No problems without heel gaurds.
The line I was referring to is where the plastic changes angles. it's clearly visible on the back side.
I did use the dremel for sanding, after cutting.
Old Dec 16, 2002 | 09:10 PM
DSjockey's Avatar
When I cut my heel cups I used a small battery reciprocating saw with a blade just like a wood cutting jig saw blade, it worked great, very controlable, made a nice cut, I'll use it again when I cut the fenders. We'll be making a proto type aluminum heel guard soon (probably right after FSW) bolt to the foot peg, simple clean design, round tube aluminum, works with nerfs...
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
