queastions about the P650
Old Dec 29, 2002 | 01:57 PM
tommyboy84's Avatar
Default queastions about the P650
I will be buying a new quad in the next month or so and I have 95% made up my mind on the peairie. I just have a few questions about it.
(1) how much problems have you been haveing out of the belt?
(2) will the black spring increas belt life?
(3) What does the red spring do and will it increas belt life?
(4) how many miles are you getting out of youre belt?
(5) If you run through deep water will you have to be pulled home or does it effect the belt?
(6) If the belt breaks can I change it on the trail?
(7) I'll probally put 27in 589s on it' will that effect belt life?
(8) Is there ANY way to switch a P650 to a manule shift????????
As you can tell I,m verry afraid of a belt drive atv but hopefully you all can answer my queastions and solve that fear.
Old Dec 29, 2002 | 02:58 PM
Lightman's Avatar
almost every single question you asked can be answered by using the search function. do some reasearch and I believe you'll find what you're looking for.
Old Dec 29, 2002 | 05:22 PM
tommyboy84's Avatar
lightman' Ive been doing a search on thoes queastions and have found SOME info but still not enough to comfort me.
Old Dec 29, 2002 | 07:50 PM
03650's Avatar
Hey tommyboy i myself have been looking into buying the 03 650 prarie. I went to nyroc's website at (atv. dnsalias.com) and he answered a lot of my questions about maintance, black spring, red spring, etc. you need to check it out if you havent allready oh by the way i plan on buying my machine in the spring, and having the black spring put on right after the 10 hr breakin period. Hope this helps a little good luck.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 29, 2002 | 09:17 PM
Andy~G's Avatar
1. None
2. Yes
3. It lets the motor rev higher before the clutch engages for snappier take offs/no
4. Judging from other peoples experience,1000 miles with a properly adjusted belt.
5. On the off chance that you get water in the clutch box,reving the motor in nuteral will dry the belt. For what its worth, if gone through water up to my headlights and havent had any problems with a wet belt.
6. Sure but you will need a ratchet,one socket{10mm I think}, and one long extention.
7. Big aggressive tires can be harder on a belt but its more your ridding style that effects its life.
8. Not that Ive ever heard of.
Andy G
tommyboy84
Nov 1, 2002 05:33 PM
kawirob
Jul 19, 2002 10:59 AM
lackdog
May 26, 2002 08:16 AM
DSaholic
Jul 24, 2001 05:11 PM
