hey got a ? on a lakota.wont stay running!
Old Dec 31, 2002 | 09:30 AM
prick's Avatar
Default hey got a ? on a lakota.wont stay running!
hey guys and girls,
my lakota wont stay running. i start it and it runs for a little while then stalls.if you hit the gas at any point it stalls,and if you go to start it again it wount start.i almost ran the battery otu. i start it with the choke out. it almost sounds like it runs out of gas.i checked the fuel line its not clogged but could it be the carb.anybody have any ideas what is wrong. i think it might be the carb,im going to check it out this weekend.
thanks
Old Dec 31, 2002 | 10:54 AM
Surveyor's Avatar
p_rick,
the censorship on this board makes it hard to reply to this message,
check the needle & seat in the carb, if it sticks it is running out of fuel,
check the pilot jets are not gummed up
this is where I'd start..
you may want to check float level as well, but this something that would not keep it from running if it was not adjusted, as long as it was close to spec, or not changed from stock settings..
Old Dec 31, 2002 | 11:08 AM
prick's Avatar
hey,
thanks for the info. i will start there. i had a feeling that was it.
thanks
Old Dec 31, 2002 | 11:16 PM
pulsar's Avatar
check to see if your vent hose on the top of the carb has a kink in it. I had a similar problem and that was it.
Old Jan 1, 2003 | 01:50 PM
prick's Avatar
hey,
thanks ill check that befor i take off the carb.
latros
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
