Solonoid problems!
Old Jan 8, 2003 | 09:34 PM
fullthrottle's Avatar
Default Solonoid problems!
This is the 3rd solonoid I had to replace. Is anyone else having a problem with this when operating your winch for plowing?
Can you eliminate the solonoid?
If so can you tell me how to wire it and if you need a heavy duty switch?Where to mount the switch?
I have it currently hooked up to a switch so the winch isnt always powered up unlike the
way warn shows the wiring with power running to it at all times.
Thanks for any help
2000 xplor 400 4x4
Old Jan 8, 2003 | 09:45 PM
Bubba297's Avatar
Your gonna need a heavy duty battery kill type switch or something like that. A winch draws a good amount of power, and it's killing the contacts. Have you thought about buying an older style Ford car or truck solenoid? They should be able to handle the draw better, be simple to wire up, and are dirt cheap.Bubba
Old Jan 9, 2003 | 10:01 PM
Yep, did that. I put a 1976 f150 solonoid in twice. The first one was the one that came with the winch that they had recalls on. Is anyone else having this problem? I forgot to mention that it was the 2000# winch. If that makes a difference? I wouldnt mind but, the winch is only used for about an hour every now and then . Thanks for the input bubba.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
