Greasing inside cv boot
Old Jan 12, 2003 | 05:59 PM
nightal's Avatar
Default Greasing inside cv boot
I was about to grease all my fittings on my Sportsman 500 and was wondering if there are zirk fittings under the cv boot I need to grease to? I have already had on of the clamps knocked popped loose by a stick and managed to get it back on but don't know if there is one under the boots I need to grease to. Also to regrease under the boots do you have to buy new clamps each time you grease under those ?
Old Jan 12, 2003 | 06:55 PM
CrispyCritter's Avatar
Nightal,
There is no fittings under the Boot. I have had mine completely apart, (Putting on a New Boot.) and the only thing that is under the boot is the Joint. If you take them off just right you can reuse them. If you happen to break one then you can use on of the super duty Zip Ties. They work But I would recommend getting new clamps. I think that you can get them at AutoZone.
Old Jan 12, 2003 | 07:19 PM
PolarisPower500's Avatar
You 'never' regrease inside the CV boots. If a boot gets ripped, the new boot will come with grease. You should not ride with a torn boot. Even a small amount of dirt will damage a CV. If everything is in good condition, they are greased for life.
Old Jan 12, 2003 | 09:29 PM
Mudracer300's Avatar
you could use a hoseclamp too i had to use one once when the clamp got tore off by a chuck of ice i kept it on all winter and had no problems
ReconBayou
Oct 16, 2019 02:24 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
bigred20653
Sep 19, 2015 02:11 PM
