Sportsman 500 pulling to side
Old Jan 12, 2003 | 06:35 PM
nightal's Avatar
Default Sportsman 500 pulling to side
I recently bought my sportsman and have noticed that sometimes it wants to pull to one side or the other. A friend of mine told me that is typical of 4 whell model atv's. I have checked the tire pressures and they are fine. Mostly it pulles to the right and it is pretty annoying because it wears your ares out trying to keep it straight especially on roads
Old Jan 12, 2003 | 06:46 PM
highwayman's Avatar
I think your hub is not releasing. If it is a new bike try taking it back to the dealer,although I don't think there is much they can do. When my 335SP does this I just back up a bit and it usually releases. In other posts some people are using Mobil 1 Synthetic ATF which I plan to try when I change hub oil.
Old Jan 12, 2003 | 06:49 PM
nightal's Avatar
thanks loads,,,I thought is was just me at first but I'm still learning the little bugs about all this. It's my first atv and love it
Old Jan 12, 2003 | 07:12 PM
lancesamuel's Avatar
I have the same problems sometimes with my sportsman500ho.. Just like what the other guy said---stop put it in reverse and go back aways and it will release.
Old Jan 12, 2003 | 11:34 PM
FishballzRFoul's Avatar
Same problem here dude. I just back up a bit and it releases. Hope that helps.
Old Jan 14, 2003 | 07:27 PM
ftwflh's Avatar
Hey guys change the hub fluid on a regular basis and it will help.And do not let it run dry!
Old Jan 14, 2003 | 10:51 PM
Ray_Card's Avatar
Hi I have a 1993 350L and it does the same thing usually after backing up in four wheel drive. I have found taking it out of 4X4 and reversing hard enough to make the rear wheels spin will release the hub. The manual I have explains what happens and how to remedy it. The new manuals may also provide insight.
Ray
Old Jan 15, 2003 | 05:16 PM
RideRed913's Avatar
What about your alignment? You might want to check that out and it would explain the side to side motion.
Old Jan 15, 2003 | 07:15 PM
ProXPredator's Avatar
If you want to save a buck or two, use Automatic Transmission Fluid instead of Polaris Hub Lube. I was using the Hub Lube for about a year, with typically leaky hubs. After I used the Automatic Tranny fluid, it doesn't leak nearly as much as before. Just an idea.
Old Jan 16, 2003 | 06:41 AM
mtpockets's Avatar
nightal, man you have to take the time and READ your Owners Manual.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
WilliamBos
Sep 30, 2015 08:08 AM
Biggieshortie89
May 26, 2015 08:01 AM
