how do i fix my starter?
Old Apr 10, 2000 | 01:35 AM
scramblinman's Avatar
i have a 99 scrambler 400, and have been having problems with my starter not releasing from the fly wheel(?). i need to know what is involved in removing the starter and fixing the problem? please help. thanks...
Old Apr 12, 2000 | 10:09 PM
Charlie's Avatar
Its probably your starter drive that is the problem. You would need to remove the recoil and the flywheel to replace it. I have done one 400 Sport that had that problem and that solved it. The only problem for you would be the cost at about $120.00.
Old Apr 12, 2000 | 10:34 PM
mudmachine's Avatar
Scramblin,
Pull the recoil housing off, take the bendix out, and if the gear teeth aren't damaged you can disassemble the bendix, clean it thoroughly, and re-assemble it.
They are expensive to replace, so I would suggest the clean and re-install method first. If all else fails, see if they sell just the wear parts for the bendix...
Good Luck..
Old Apr 13, 2000 | 12:06 AM
atving's Avatar
Read this stuff at this site scramblin man and then let me know what you think...seems it may be a problem that all of us Polaris riders are going to suffering from sometimes...seems doing a better seal will be the cure to the problem...let me know what you think...oh yes the site is:
http://www.atving.com/editor/techtips/techtip3.htm
Old Apr 13, 2000 | 02:04 AM
Jaime's Avatar
I just want to check and see if people check there recoil housing for water when they have be in real deep it can be drained bye removing a bolt under the housing That is just FYI
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
