?39FCR to Alky?
Old Jan 21, 2003 | 01:17 AM
RAZOR13's Avatar
Default ?39FCR to Alky?
does anybody know who sells a kit to convert the fcr carbs to alky using just jets? Sparks stoped selling his!
thx's for any info
Old Jan 21, 2003 | 07:35 PM
AlkyBurninX's Avatar
Call FTZ at 573-334-5439. You will also need a new needle and will have to remove some air jets. They can tell you what is needed. Wade usually answers the phone.
Old Jan 21, 2003 | 08:09 PM
RAZOR13's Avatar
ALKY-----
THX's for the info. [img]i/expressions/face-icon-small-smile.gif[/img]
was it you that gave a nice read on how to change over to alky last year?It was a good read I should of printed that!
good luck w/your 350 last year i saw an old 350 all beat to h*ll beating all kinds o f banshees even a couply of 370 he had a Sparks big bore 92mm kit in it .it was the ultimate sleeperrrrrrr
thanks again
Old Jan 22, 2003 | 02:55 PM
Have you called FTZ yet? If you pm me I can help with the conversion and jetting.
Powroll is doing my crank, FTZ is installing my sleeve and boring, the company that custom ground the cam for my 521 ford stroker in my 68 truck is grinding the cam after the head is flow benched. As of right now, I am doing my own porting. I have access to a flow bench so I can do it trial and error. The hardest part is going to be starting the thing. My 410 kit in the 250x engine that I have now is above 14.5:1 compression. The 454 kit in the 350x engine will be almost 15.0. I hope the 39 FCR that I have now will be enough for the high reving 454. I already have a 35 that I orginally bought for the 250x and I don't need a third $400 carb.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 22, 2003 | 03:07 PM
Kenzcycle's Avatar
WE have had good luck using a OFFB-B NEEDLE on the 4th clip frim the top, from SUDCO.And reeming the e-tube to .115 as well as the main jet. This is a starting point on the main jet!! I would recomend a PINGEL fuel valve also.
Old Jan 22, 2003 | 08:47 PM
Kenzcycle, you had to ream your dump tube? .115 is a good starting point. Run a good plug such as NGK platinum with a 9 heat range at .018 gap.
AdamsBadDS650
Feb 4, 2003 10:39 PM
trborowe
Feb 3, 2003 04:41 PM
AdamsBadDS650
Jan 20, 2003 11:08 AM
pudjumper
May 22, 2002 04:39 PM
demp223
Apr 28, 2000 08:48 PM
